crank position sensor
I need info for a 2007 with the 2.2 engine. I need to know the location of the crank position sensor and the procedure for replacement. Thanks in advance, I'm sure this is simple I just don't know these engines very well.
It's on the front of the engine, just below the housing for the oil filter, held in with a bolt. It is immediately adjacent to the Oil pressure switch. It should be a straight forward matter of removing and replacing.
