Crank position sensor
Old Aug 12, 2021 | 07:38 PM
Madmec's Avatar
Hello everyone. I was wondering if any one else is having the issue I am having. I am getting codes for the crank position sensor and I believe its not getting enough volts. I tested the wires and I'm getting 5 volts from 2 of the wires and I assume the 3rd is the signal wire. The only thing I can think of is one if the control modules are bad or their is a short.
2010
2.4l
Old Aug 12, 2021 | 07:44 PM
HHR ?
Year ?
Engine size ?
Old Aug 12, 2021 | 07:46 PM
Madmec's Avatar
Hhr
2010
​​2.4l flex fuel
Old Aug 12, 2021 | 07:50 PM
Welcome to the site And most importantly, what exactly are the codes? P0???
Old Aug 12, 2021 | 08:12 PM
Madmec's Avatar
P0335
p0365
Old Aug 12, 2021 | 10:20 PM
IF all of the wires and connectors are good the sensor must be bad.
P0365 is NOT the crankshaft sensor it IS the exhaust camshaft sensor. Likewise a wire/connector/sensor problem.
Here are the testing procedures:
P0335
P0365
Old Aug 13, 2021 | 02:33 AM
Madmec's Avatar
Do you by chance know what each wire is by cable color. I was getting 5 volts between two of the wires and nothing on the 3rd. If I'm understanding the procedure correctly I probly should replace the ecm
Old Aug 13, 2021 | 06:13 AM
It is rarely the ECM that’s the problem
Old Aug 13, 2021 | 08:30 AM
Old Aug 13, 2021 | 09:08 AM
I do notice to inspect the timing chain and oil debris in the P0335 description, a loose chain will through off the cam and crankshaft position correlations
How many miles since last timing chain and tensioner?
