Cranks but won’t start
Listen to Old Blue about the ZZP chain guide. (PSA, if your black one was installed with the alternative bolt, it is possible to retrofit the ZZP guide without removing the chain or any other guides. It is however necessary to remove the cover. Ask me how I know.)
Also consider buying GM tensioners. Both timing and balance chain. Generics are iffy, and if they malfunction, a cascade of failures ensues.
Read this , memorize it! Especially the part about timing marks and lining up the camshafts during reassembly
https://www.ddmworks.com/assets/imag...uild%20Kit.pdf
