Originally Posted by donbrew
(Post 757389)
Check the large red wire connection to the fuse box.
We are off to get a new battery. I'll let you know how the car is working after that
Husband checked fuse 28 and it tested ok. |
Hooray........New battery............car is ok............Thank you all for your guidance and help. Bless you
Welcome to the site ,enjoy that HHR!
Oh no....new battery....car ran great for l day and then did exactly what it did to start this mess.....any thoughts...thank you
fuse box under the hood, as mentioned earlier in this thread
Get the charging system checked. Sounds as if it's not charging the battery back up.
... and most Auto parts stores will test the charging system for free (as they do for batteries).
well, no charging problems.....our mechanic is looking for a drain on the battery.
Thought....We had the ignition replaced by dealer here according to recall. Since then we had key stuck in ignition switch because of a part failure (don't remember name but I remember part cost 500. Gas mileage down to ll miles/gallon. Now this electrical drain. Up to this point, we have had no problems with this car in 5 years and 97,000 miles. Anyone had problems with this recall? Thank you for any help. |
Have your guy check the throttle position sensor. When they go bad they can cause a drain, usually it throws a code......but.
