Cruise and info stop workin
Hey all , i did the steering wheel radio mod on my 08 Panel.Everything went together with no problems.Started up the panel and the radio control on the steering wheel works great :thumb: But the Cruise and the info stop working.:eek: So i took the airbag/horn off again and rechecked my connections all was good.:thumb: Try again, still no cruise or info:( .So i reinstalled the orginal harness and the cruise and info works perfect. Need some Help please Thanks Ric
I'd say that your parts swapping indicates that either the replacement harness or cruise switch is at fault.Try switching just one of those two components again and see if things change.If the functions start working,there's your problem.If not,then it has to be the other piece.
Originally Posted by ZTony8
(Post 315032)
they should all be the same. I purchase one of ebay and every thing work just fine not sure what year it was off, but mines an 08. Make sure nothings getting pinched I heard some one had problems with that. other wise I would say you have a bad harness.
check out the pinouts on the cruise side of the harness against the new harness and I think you will find the wires connect differently. Just compare the color codes from one to the other. You need to change the new harness to match the existing. Additionally, you may need to change out 1 and 4 on the radio side, swapping them around. This worked on my 08.
Originally Posted by jdmcomp
(Post 315201)
Cajun |
Check post # 478 of this thread https://www.chevyhhr.net/forums/show...t=1912&page=48
Thanks guys for the info:thumb:
(Post 315201)
