Adding radio buttons on steering wheel
Old Feb 13, 2008 | 11:42 PM
  #471
shaginwgn's Avatar
Originally Posted by Karmike2
Fontana Motorsports,
What color is the 15907681 part number for?
Also would you only have to swap over the air bag?
Thanks
Here are your answers:
Originally Posted by fontana motorsports
just order a new wheel, i just bought a new gray leather one, and it comes with the cruise and radio buttons and harness.. part # 15907681
From another thread:
my local dealer. it took 10 minutes to install.... push in tabs remove airbag, disconect airbag conectors (at the bag) unplug cruise harnes, loosen steering wheel nut (19mm) pull on wheel, remove nut, put new wheel on,hook up conector ,airbag, snap the bag back on and sdone.
so you need to swap the airbag
Old Feb 13, 2008 | 11:45 PM
  #472
Karmike2's Avatar
Oops...thanks. I just read the other post after I had already left the questions on this thread!
Old Feb 13, 2008 | 11:51 PM
  #473
shaginwgn's Avatar
No problem added one now two more posts on my post counter
Old Feb 13, 2008 | 11:55 PM
  #474
ricerocket's Avatar
plug and play
guys, does this mod only work for the factory headunit? or will this mod no longer be plug and play with an aftermarket HU?
someone please answer, since i think this is a great mod...but i have an LCD aftermarket HU.
Old Feb 14, 2008 | 12:05 AM
  #475
shaginwgn's Avatar
In order to keep or have steering wheel controls with aftermarket HU, you will have to get an adapter to make it work. A company that makes them is PAC and will be around $60-90
Old Feb 14, 2008 | 04:03 PM
  #476
ricerocket's Avatar
hey thanks for your answer. now i know!
now does anyone know which specific PAC adapter that is to allow steering control for an aftermarket HU? part number? or a link?
Old Feb 14, 2008 | 11:28 PM
  #477
shaginwgn's Avatar
PM sent...back to the regular scheduled thread
Old Mar 9, 2008 | 02:37 PM
  #478
blocker44's Avatar
Originally Posted by ellis ewe
cruise side original, new harness needs to be this way
1 2 3 4 5 6 7
1-green, white tracer
2-open
3-gray
4-pink
5-gray,black tracer
6-open
7-black,white tracer
this is looking at plug from side that has 7 holes in it
new harness will come wired this way (at least both of mine did)
1-open
2-open
3-black, white tracer
4-pink
5-gray
6-gray, black tracer
7-green, white tracer
Radio side will come this way
1-blue, white tracer
2-white, black tracer
3-gray
4-black,white tracer
1-black, white tracer
2-white,black tracer
3-gray
4-blue, white tracer
Again, looking at all plugs from the side with holes
I just finished the mod, but had to re pin the connectors as in this post. How did you know to swap the two wires on the radio side?
Now I just need to get the right color bezel. I got the silver one and will need the dark grey one.
Thanks to all who put this thread together.
Old Mar 9, 2008 | 03:16 PM
  #479
tooter1's Avatar
Will this work for the base model radio?
Old Mar 9, 2008 | 10:44 PM
  #480
oneton's Avatar
Yes It Will
