Adding radio buttons on steering wheel
Well, I finally installed my controls. Install wasn't all that bad, but I did have to change all but one pin on the cruise control side.
As for warranty, changing the controls will void the warranty on them no matter who does it, or where you get them from. Unless of course the dealer never looks into what your car had from the factory, and doesn't care that you changed it. Lets just say if they want to be *****s about it, they can be.
Got mine installed, too. Like Kawtipping above, I ended up changing all but one wire on the cruise side of the harness...but also had to swap #1 & #4 on the audio side. Works great!
Still waiting for the cover, though.....................................
Buttons are currently dangling out of the hole.
I have a 15842365 flat button switch and 15234337 silver cover that I will gladly trade or sell....I need the Dark gray and raised button setup...sell the cover for $10 and the switch for $20 which is rounded below what I paid..now to search out the right numbers....(groan)
Looking back thru the threads..it appears GM was not consistant with the colors to year model..I have an 07 with the gray switch covers while everyone else has the silver..hmmmm...and it appears some have flat while others have raised buttons..I have the raised..
So..if I'm now correct,,the raised buttons are PN 15942446 and the Dark Gray cover is PN 15281577..is this correct?
The saga continues..after re=reading the entire post..again...my conclusion is...paint the suckers!! I ordered the 15234337 bezel and got silver..the 15281577 from what I read is also silver..??????? What gives? Anybody have a GOOD number for the gray..or has one they would like to part with? The parts I have now were sold so post 454 no longer applies...my hair is starting to match the 577 part...................
