Damaged pan, Run without oil
Old Oct 3, 2006 | 11:33 AM
tomdent1's Avatar
Originally Posted by courthousedeb
Sounds like it's a possibility that it seized up. Did you see any codes on the DIC? It also sounds like the dealership might be blaming you for the problem so it won't be a warranty issue. I would definitely get another opinion before just taking their word for it. You might want to go to an ecotec engine forum and present the same question if no one here can provide any insight.
Sorry to hear bout the problem...please be sure to keep us updated.
Explain to me how this could be a warranty problem. How could anyone blame this on GM? This is not a warranty problem. If the engine suffers any problems down the road GM should not be responsible. Now isurance on the other hand , if you have coverage.
Old Oct 3, 2006 | 12:53 PM
AMHobby's Avatar
The engine should turn over. It is possible the starter is also fried from trying to start a siezed up engine. Maybe all of the oil drained out while you were parked and the drive just finished it off. Probably engine time. Or maybe what ever you hit also damaged some wiring. Either way your comprehensive insurance should cover it.
Old Oct 3, 2006 | 02:11 PM
SindyDix's Avatar
What Southern Califoria dealership was this at?
(funny side note: ad banner on the bottom of this thread at the time of my reply is for www.GM-warranty-online.com)
Old Oct 3, 2006 | 04:15 PM
georgeb's Avatar
Rotolo Chevrolet in Fontana. I had never been there but it is closer to my home than Mark Christopher.
They pulled the engine, and tried to turn it with a wrench. nothing. Guess it is seized.
Old Oct 3, 2006 | 08:33 PM
BlackHHR's Avatar
that sucks
So now you have to get a engine
Old Oct 3, 2006 | 08:54 PM
Angelo's Avatar
Gm not responsible ? If he simply pulled off the road to get something, and hardly scrapped anything, it should not have made a hole in the oil pan. And if it did, its due to GM's poor design of an oil pan. They should have put a skid plate down there if it is that close to the ground and the cheaply made. If that happened to me, you can bet i would have my car sitting at the service door, ready for GM to put a new motor in it. But, then again, that is how i look at it.
Old Oct 3, 2006 | 09:43 PM
simca1955's Avatar
I would say that it takes more than a mere scrape to crack, burst, or rupture a oilpan of any kind. And one that is a designed structure of the engine even more hit needed. And i would say that a piece like this would crack before being punctured, or at least chunk out. So anyway I wouldnt think gm could have prevented this. Insurance... Wait for that turbo engine and put that in it. just kiddin. sorry for your luck. John
Old Oct 3, 2006 | 10:03 PM
tomdent1's Avatar
ROFLMAO
Old Oct 3, 2006 | 10:11 PM
tomdent1's Avatar
If I simply drove into a telephone pole , I guess could blame GM for not having an accident avoidance system that would have took over driving for me and prevented me from hitting the pole!
Anyway back to the issue I hope insurance will cover the motor.
Old Oct 3, 2006 | 11:16 PM
Angelo's Avatar
Hold up, what is so funny ? Im not trying to start an argument here. I say he tells them to replace it if the oil pan does not look to bad. What can they say, no ? I actually do warranty work for the dealerships and know first hand they cover some things you would not imagine. Say paint chips. If you live on a gravel road, you will obviously have chips. What does the dealership do ? Paint every piece of the car that is chiped. This gets expensive, especially with Cadillacs when you have to paint the whole side of the car. If the dealership will cover it, why not let them ?
