damn dinging
Old Nov 9, 2017 | 09:27 PM
bailbud's Avatar
damn dinging
not sure what might be the issue , just got the car an 07 HHR but most of the time when we remove the keys the car is dinging and ringing like the keys are still in the ignition . any ideas b4 i take it to dealer , the remote start won't work I'm thinking its b/c the computer thinks the keys are still in ???
Old Nov 9, 2017 | 09:36 PM
Has the ignition recall been done?
Old Nov 9, 2017 | 10:05 PM
bailbud's Avatar
not sure , don't think so
Old Nov 9, 2017 | 10:23 PM
https://my.chevrolet.com/recalls
Old Nov 9, 2017 | 10:27 PM
Are all of the door switches working? Are the headlights set to "auto"? Is the CheckEngineLight on? Is the hood securely latched? Is remote start turned on? Have you read the Owner Manual? There's a link in my sig.
Old Nov 22, 2017 | 08:08 PM
bailbud's Avatar
went to the dealer today 9100495-n140113 replace ignition lock cylinder and the 9100400-n140063 replace ignition and start switch are the recalls that have been done .Are all of the door switches working? Door switches all seem to be working . Are the headlights set to "auto"? Headlights on auto Is the CheckEngineLight on? the check engine light just came on for "power steering". Is the hood securely latched? yes Is remote start turned on? not sure how do you check it Have you read the Owner Manual? some of it
Old Nov 22, 2017 | 09:03 PM
The remote start in off is in the DIC settings use the cruise control switches to access , as directed in the owners manual.
Old Nov 22, 2017 | 10:13 PM
There is an extended warranty on the power steering if the warning is displayed.
The car is trying to tell you that something needs to be turned off or closed. The hood has a switch in the latch that sends a signal for "closed" if you have AP3 on the label on the glove box door.
The hatch switch also sends an "open" signal.
Each door has a light switch, they send an "open" signal, they sometimes get sticky.
Old Nov 22, 2017 | 10:44 PM
Don, none of these things cause a chime on my HHR. I get chimes if I leave the key in and open the driver door. No other door, hatch, or hood causes a chime. If I turn the headlights "on" and remove the key, I get a faster chime.
So bailbud, with key in the ignition, open driver door. Hear the chimes. When you take the key out, do the chimes get faster?
Old Nov 22, 2017 | 10:49 PM
bailbud's Avatar
will try it and see
