Dealer Oil Chage, now AC doesn't work
Old Jun 8, 2020 | 09:37 AM
tiapetra's Avatar
Originally Posted by joepepsi
Serpentine belt is fine and all fuses, breakers, and diode appear fine too. I notice the idle does jump up slightly when turning on the air, then drops back to normal rpm.
The initial jump in idle should mean that the compressor is pumping, but check to make sure the shaft is turning , not just the pulley.
If so, then the next step would be to put on a set of guages and check the pressures.
Old Jun 8, 2020 | 09:41 AM
I reseated the MAF sensor but still no go. Could I just need to add refrigerant?
Doubtful. If it was working before, then quit right after the oil change, then it's probably something the oil change place did.
Did you go back to them and ask them to take a look ? I would.
Old Jun 9, 2020 | 11:25 AM
joepepsi's Avatar
I asked them to take a look and they scheduled an AC check for Friday. I asked if there was a cost involved and he said, $120 for diagnostic, drain and refill. I paused. He said, we could look around for any loose wires or disconnected parts, but we don't touch the AC as part of our oil change. About what I thought they would say. A friend of mine has added refrigerant to his Blazer and says it's not a big deal. He's pretty good at most repairs. Maybe I'll ask him to take a look.
Old Jun 9, 2020 | 11:55 AM
Like I stated, if it was working before then quit after the oil change, it's most likely NOT a low freon issue. I am familiar with auto AC's. Used to do a lot of AC work back in my mechanic for a living days.
If that shop won't take a look at it for free then you should steer clear of that bunch in the future.
Old Jun 9, 2020 | 12:03 PM
joepepsi's Avatar
I will never go back. On Star has my upcoming service appt written up as this:
Reason for Appointment
  • CUSTOMER STATES SHORTLY AFTER LEAVING THE DEALERSHIP AFTER LAST LOF/ROTATE SERVICE ON 6/2/2020 THE AC STOPPED BLOWING COLD AIR. WAS COOLING BEFORE. CHECK OVER FOR ANY UNPLUGGED CONNECTORS, OR ANYTHING THAT MAY HAVE BEEN DISCONNECTED AT OIL CHANGE ETC. IF HAVE TO PERFORM AC SYSTEM SERVICE CUSTOMER TO AUTHORIZE $120.00+TAX TO PERFORM.
So, I guess I could take it in and only authorize them to check it over for anything that may have been disconnected.
working on it
Maintenance and Upkeep
34
Feb 24, 2013 06:41 AM
IgottaWoody
18
May 19, 2011 04:17 PM
Lone Ranger
Jul 4, 2007 12:52 AM
SIHHR
Feb 14, 2007 07:35 PM
trey1966
Aug 28, 2006 06:51 PM
