dic, radio display
Old Jan 21, 2012 | 04:23 PM
john's Avatar
dic, radio display
dic, mileage and radio displays are out upon starting but come on a short time after I start driving. Radio and everything works during this time. Looking at the fuse box I cannot find a lighting display fuse. Anyone know where to look? It just started this about a week ago. 2006 year model.
Old Jan 21, 2012 | 04:55 PM
Did you look in both fuse boxes? Not sure about 2006 fuse locations. If it comes back on, then I assume the fuse is not blown.Might try the trick of pushing all the fuses in to make sure they are seated tightly.
(2010 owners manual shows #62 as instrument cluster:under hood fuse block)
Old Jan 23, 2012 | 10:33 AM
db/sb's Avatar
2006 owners manual shows the same.
Old Jan 23, 2012 | 10:36 AM
esmarkey's Avatar
This may sound stupid, but have you tried turning the dimmer switch? It may have a poor contact...
Old Jan 23, 2012 | 10:41 AM
john,
I'm sorry you're having this problem. The cluster fuse is #7 in the floor console fuse block, it may be lose. If the problem still persists I would suggest having it diagnosed y the dealer. Please keep us updated, thank you.
Evan, Chevrolet Customer Service
Old Jan 23, 2012 | 10:44 AM
Originally Posted by ChevroletCustomerService
john,
John,
firemangeorge was correct about #62 being the Instrument Panel, Ignition fuse on the engine compartment fuse block. I would check both.
Old Jan 23, 2012 | 03:14 PM
john's Avatar
Thanks for the replies and suggestions. i haven't found any problems yet. The mileage display always shows when door is opened like it should. Once the display comes on,usually within a mile it stays on with no problems until a restart. It never goes on and off like a bad connection. I'm thinking a possible relay prob somewhere. Anyhow I will get it checked by the dealer if it gets worse.
Old Jan 23, 2012 | 08:09 PM
db/sb's Avatar
Here's a post from ChevyMgr from a couple of years ago that could be useful:
https://www.chevyhhr.net/forums/show...21&postcount=6
howardt
Mar 12, 2013 08:49 PM
osie59
Jul 19, 2012 02:44 PM
clobert
Mar 19, 2011 11:01 AM
rsully745
Jan 29, 2011 10:44 AM
Hellraisehr
Aug 27, 2007 09:38 PM
