Dome Light Bulb Replacement
"Okay, I'm an idiot. How do I open my '07 HHR dome light assy. to R&R the light bulb? "
When I replaced my bulbs, I just popped out the clear covers, but the service manual says to "lower the headliner to gain access to the lamp housing" no more detail than that.
Does anybody know the blub types in the 2007 Dome Lights??? I want to replace with LED Bulbs instead!!! I can't find this info anywhere!!??!? ChevyMgr?? I need to know the blub numbers. If anybody can find these please help! I've been to Sylvania, and that doesn't have the info I need, I don't think they are accurate anyway, for this application.
First Bulb is Called a Festoon Bulb, LED's / Super White / 44 mm Wire Loom, 2/3 rd's of the way down this page:
http://autolumination.com/festoon.htm
The LED replacements for the 194's is a: 194 Flank Style LED which can be had here on ebay:
http://cgi.ebay.com/ebaymotors/V-LED...Q5fAccessories
The Second Ones are Pricey but will illuminate the P!SS out of the rear of your ride! We are using these also on the License Plate!
Good Luck,
