Dome light replacement?
Old Jan 24, 2014 | 03:42 PM
jbounds1's Avatar
I have an '09 SS that has a sun roof. The housing where the dome lights are, also houses the controls for the sun roof. I am needing to change the bulbs. Any idea how to remove the old bulbs? Don't want to break anything!
Old Jan 24, 2014 | 05:34 PM
Look in your Owner Manual, if you don't have one use the SEARCH box at the top of the page for a PDF manual.
The lens has a couple of tabs to press, the OM will show you where they are.
Old Jan 25, 2014 | 06:32 PM
jbounds1's Avatar
Thanks. Checked the PDF manual, however, it doesn't show how to change the bulbs. I really don't want to break the lens or the housing and the OM nor the PDF manual explain the procedure. I don't want to pay a dealer either.
Old Jan 25, 2014 | 08:35 PM
Lucky's Avatar
I found this thread that may help. It has some pictures of the dome light with the lens removed.
https://www.chevyhhr.net/forums/appearance-modifications-discussions-6/led-lights-29991/
Old Jan 25, 2014 | 09:41 PM
jbounds1's Avatar
Dome light
I hate to sound ungrateful because I'm not but that thread didn't show me how to remove the lenses, just that they do in fact come off. I appreciate all the reply's. Please keep them coming!!
Old Jan 25, 2014 | 10:37 PM
OK, get up close to the lens and look for the indents somewhere around the edge. That is where you are supposed to gently insert a small plastic pry and pop it out. If you cannot see obvious points to do it, you are doomed to paying somebody.
If you look closely at the pics in the thread you may be able to see the tabs. It is not held in by magic, just friction. If you were to put your fingers on it and try to move it around you could probably see them. Sorry, it's something you have to learn by trying.
Old Jan 26, 2014 | 08:15 AM
jbounds1's Avatar
Lol. Thanks buddy. I'll give it a shot and let you know how it goes!!
Old Jan 26, 2014 | 04:11 PM
OK, buddy.
Old Jan 26, 2014 | 10:26 PM
jbounds1's Avatar
Got the lens off with a little persuasion and got the bulb out. When i put the new bulb in, it didn't work so it was all for nothing. Be careful putting the light back in as to not push the bulb housing back into the housing like I did. Finally got the original bulb back in. I'm done!! Thanks donbrew for your help.
Lethal Tendencies
Mods - Interior
18
Apr 15, 2015 11:53 AM
av61HHR
Oct 17, 2011 02:16 PM
Wellard
Jan 3, 2011 09:23 AM
twr4d
Sep 20, 2009 11:22 PM
norcalmike
Jul 8, 2008 11:29 PM
