Door chime keeps chiming
Old Dec 8, 2013 | 01:25 PM
FSU_Noles's Avatar
hello everyone,
I have searched the forum and the faq's and cannot find a solution...
When I take my key out of the ignition and open the door to get out my door chime sounds. I have my keys in my hands, headlights are on auto, dome light is off, radio is off, seatbelt is off, all other doors are closed. I can only imagine that something is still on that I can't locate or turn off. It has done this once before and the next day my battery was shot. I have replaced the battery and did not have the problem for about 2-3 weeks, now it has returned.
Help!!
BTW, 2008 2.0L.
Old Dec 8, 2013 | 01:37 PM
First thing, do the headlights go off after 50-10 minutes? Do you leave the headlights on auto or do you turn them on when you drive?
The first night I had my 2008 LT I had not had a chance to read the OM and did not understand auto headlights. I drove 700 miles at night, got home at 4 A.M., at around 6 A.M. I heard somebody tap on their horn in my driveway. Turns out the headlights were on and that horn beep was the battery warning.
Could be the power retention system malfunctioning. Brake pedal hanging up on the switch.
Old Dec 8, 2013 | 01:50 PM
Hi FSU Noles,
I can surely understand your concern for why your vehicle is behaving this way. Are you planning on taking it into your dealership to get it looked at? We are here and happy to help in any way we can. Feel free to PM us your name, contact information, VIN, current mileage, and preferred dealership if you would like us to look into this further.
Sincerely,
Jonathan A.
Chevrolet Customer Care
Old Dec 8, 2013 | 01:52 PM
FSU_Noles's Avatar
My headlights are on auto. I have had this car for 4 years and never had this problem. I bought a new car and the HHR has been sitting but I still start it and drive it once a week or so. I can check the brake pedal but the brake lights are not on.
Old Dec 8, 2013 | 05:36 PM
FSU_Noles's Avatar
I completely turned off the automatic headlights and the chime stopped. After 4 years I am not sure why that would be a problem - but as I said, this was only the 2nd time it did this so I can't be 100% sure of the fix.
Old Dec 8, 2013 | 05:55 PM
I wonder if there is a relay sticking somewhere.
Old Dec 9, 2013 | 03:15 PM
mikiec's Avatar
I have the same issue. If I push the door switch the chime goes off. I will try turning off the auto headlights.
Mike
Old Dec 9, 2013 | 03:36 PM
thunder94's Avatar
try a little contact cleaner in the ign switch, I have had cars into the shop that the key sensor sticks, might think the key is still in it.
Old Dec 10, 2013 | 02:20 PM
Could also be a sticky door sensor, WD-40 again.
Old Dec 11, 2013 | 07:15 PM
FSU_Noles's Avatar
How would I do that? on the tumbler or in the keyhole?
