Door will not unlock
I have a 2007 HHR and this morning when I went to go to work my drivers door will not open the knob appears to go up and down so I assume the motor is working. And the key will not unlock it either. When I try and manually pull up or push down on the knob there doesn't appear to be resistance or click like the other three (3) doors.
Anyone have any suggestions. |
Need to clean and lube the latch assembly
Sounds like the linkage has come loose inside the door. Most likely at the point where it connects at the lock cylinder.
A locksmith or body shop may be able to get it opened.
lubed the latch
Well I read on another post about banging on the door below the lock, I think it was called the fonzie fix. And it.opened. so I sprayed the latch and.rotated the lever inside the latch and it appears to be working again.
Thanks for the help and responses. |
Originally Posted by Bunky
(Post 770507)
That's the Arthur Fonzerelli fix , now that he is a senior, aaahhhhh!
