Driver side door wont unlock
Ive had my 2008 hhr for now 2 years. Its been good to me. Its driven me all around the state of texas. The one main drawback is the driver side door however. Now ive never had a keyfob for this car and have always used the lock manually. At time when going to unlock the door it has been hard to turn and unlock acting like something is holding it. However 1 year ago. The key would just no let me into the car. The key would turn the lock clyinder but the silver knob would not budge nor unlock. I ended up calling a locksmith who had to pull on the the silver knob to unlock it.
Few weeks ago my chip key broke trying to unlock the door as the cylinder acted hard to turn. Eventually i put the key into a vicegrip and was able to get in. And 145 dollars later i had 2 new keys. TODAY. It happened again. The key would turn the cylinder but it would not unlock and the silver knob would not go up. I tried forcing it to no avail. Eventually i got a screwdriver and clothes hanger to pull up on the silver knob. and something was pulling it back down. It would not unlock. and eventually with all the pressure it broke. PISSED i grabbed some vicegrips and the key. And with the silver knob had being pulled up most the way. And going nack and forth left and right with vicegrips and key it finally popped loose. I have locked an unlocked the door from the inside with buttom a thousand times trying to make something get stuck. It takes two times to lock my door. When i press ot the first time it beeps three times then if i press it the second time it will go ahead and lock. I also turned the car on and off while adoing this. And also tried manually unlocking/locking the door from the outside with the key with no friction or something trying to hold it back. Any tips on what to do? Ive tried lubing up the keyhole, however the cylinder to me i dont believe is the issue. Any tips are appreciated. |
Obviously it is a problem inside the door. Either the latch mechanism or the linkage to it.
Did anybody ever think to remove the door card and look? Seems a locksmith would have suggested it at an extra fee. |
Originally Posted by donbrew
(Post 867530)
Clean the lock and latch assembly and use a lubricant , to loosen it up.
If you find broken parts send hellshotrod a PM he is clearing out his collection of parting out HHR’s |
Originally Posted by oldblue
(Post 867537)
clean the lock and latch assembly and use a lubricant , to loosen it up. ...
I think it is beyond cleaning and lubing; slimjims tend to break things.
Why not just get a key fob ?
I don’t see mention of a slim Jim, just pulling on the silver lock knob.
I have done it by own without taking help of any I have taken help from online videos and have unlocked it.
