Driver's door doesn't lock from remote
I guess I should just take the door panel off and give it a try. I need to replace the door lock switch anyway as it doesn't light up anymore and I could kill 2 birds with one stone.
Door Lock
With mine it seems to only stick on cold days (40 degs or less) had it at the dealer and they had it for 3 days and did nothing
the other day could not even open it with the key
. it will get fixed !!
drivers door latch
I have a month old '09 Panel and I could start it up with the remote but it wouldn't open up the drivers door,only the passenger side . I would have to reach over and pull up the knob . It's a good thing I didn't have smoothies like my '06 . I took it to the dealers and they knew right away that the latch had to be replaced . It is a problem with the '09s . Mine was the third one that they changed.
Now it makes me think that something is going to need to be repaired/replaced.
Worth a look. I'm not familiar with the workings inside the dorr. If there are any open linkages maybe lubing will be the solution. On my sportscar the unit is a sealed box and there is nothing to lube to fix a weak locking door.
OK, but why would this get worse over time? I mean, how would the hole around the door lock get smaller? Not trying to be a smart a--, just trying to understand.
