Driver's seat heating pads part number and source
Old Dec 29, 2022 | 01:18 PM
aethelstan's Avatar
I have a 2010 HHR LT1 and I want to fix the heat pads in the driver's seat. I am not sure what parts I need. I think there are 2 heating pads. But I don't know the part numbers or where to get them. I know I will need some hog ring pliers to get the seat cover off. Can someone help? Should I use OEM heating pads or are there decent aftermarket alternatives?
Old Dec 29, 2022 | 02:16 PM
aethelstan's Avatar
It looks like the back heating pad is part # 25972194 and the bottom heating pad is # 21994493, but I can't find the bottom pad anywhere online. It would also be nice not to spend $250 on them before labor.
Old Dec 29, 2022 | 02:43 PM
greg8453's Avatar
What makes you think the heat elements are bad? Junk yard maybe.
Old Dec 29, 2022 | 02:46 PM
aethelstan's Avatar
The driver's side seat heater doesn't work, but the passenger side heater does work. I think they are on the same fuse, so I don't think it is the fuse. I suppose it could be the connection, but I have read that the elements in these heating pads often short/break.
Old Dec 29, 2022 | 02:52 PM
to the forums!
I'm also seeing
HEATER. Front/Rear Seat Heater
Part Number: 21994364
Fits HHR (2006 - 2011)
HEATER,D/SEAT BK.
And for passenger side
Heater. Seat. ELEMENT.
Part Number: 22734070
PASSENGER SEAT. Seat heater pad. back. cushion. Pad. STRIKER.
Fits HHR (2006 - 2008)
HHR; Seat Back; Right. PASSENGER SEAT.
I'm seeing verbiage that seems to indicate that the lower element (seat) is the same part for both sides.
Old Dec 29, 2022 | 04:47 PM
greg8453's Avatar
I would at least measure the resistance of the elements. Not really a problem with them shorting out they do go open.
Did the back and bottom both go out at the same time?
Old Dec 29, 2022 | 08:14 PM
You could probably get a full seat at a junkyard for $100.
Old Dec 30, 2022 | 01:01 AM
geg's Avatar
geg
There are a lot of universal heaters on sale ... And they are very cheap.
China produces them by the ton.
pg318
Mods - Interior
Mar 14, 2016 08:48 PM
Silverfox
Jan 24, 2016 03:51 PM
mmullican83
Mods - Interior
Apr 15, 2013 09:59 AM
jpaulabbott
Maintenance and Upkeep
0
May 24, 2011 10:40 PM
longhornss
Sep 19, 2008 06:10 PM
