Drives only in reverse
Old Mar 3, 2018 | 08:19 PM
chevyhhr09's Avatar
Car will only drive in reverse.
Old Mar 3, 2018 | 08:29 PM
I guess you need a trans shop, unless you know how to get to the solenoids.
Old Mar 3, 2018 | 09:26 PM
Posting here is free, you're not charged per letter or word, so please feel free to provide any information that might be even remotely relevant.
Old Mar 4, 2018 | 12:08 AM
Actually - he only made a statement (well, two, if you count the title) - he wasn't actually asking for help or suggestions.
(my bad - sorry, just my sense of humor)
Old Mar 4, 2018 | 06:07 AM
Get a neck brace and a good chiropractor!
I’m here we’re here till Thursday, try the veal and tip your waitress, please.
Have heart , is it an automatic or a 5 speed?
Old Mar 4, 2018 | 08:00 AM
Casa Del Gatos's Avatar
Well ...
Old Mar 6, 2018 | 04:17 PM
chevyhhr09's Avatar
Transmission problems
Hi everyone. Hoping you can help me... My hhr 09 stopped moving forward. It only goes in reverse. I had it towed to a shop and he put transmission fluid in and it still does not move in drive. 110000 miles on car. There were no symptoms of hard shifting or anything. It's an automatic transmission. No warning signs. No engine lights. Last week I changed a fuse for my power windows in the box in the engine. He told me I need a new transmission of which I cannot afford. Is there anything else it could be like fuses or linkage or anything possible that I should have him check? Any help would be appreciated!!!
Old Mar 6, 2018 | 04:25 PM
Threads merged. You never came back to the other one.
Could be the linkage, a solenoid or something internal.
You could look at the linkage and see if it is moving.
All other things are a job for a TRANSMISSION shop. Adding fluid for your symptom is not a cure for anything.
However, even trans shops don't fix trannys anymore. "if it's broke, replace it"
Old Mar 6, 2018 | 06:09 PM
chevyhhr09's Avatar
Thanks donbrew. I think I need to have someone else check it out. I'll get back to you and let you know how it turns out... Thanks... Could it have anything to do with the fuses?
Old Mar 6, 2018 | 09:06 PM
Fuse #43 is for the transmission.
If you managed to touch the TCM with a hot wire that can trash it. That is one of the silver boxes in front of the fuse box, supposed to be under a plastic hood.
