dtc codes
Old Jul 10, 2011 | 04:41 PM
thumperz's Avatar
dtc codes
im too cheap to buy a scanner,and was wondering if anyone knows how to pull out codes from the pcm.
theres gotta be a way...
Old Jul 10, 2011 | 05:02 PM
Andy2.0's Avatar
Autozone or most other autoparts stores can scan it for free.
Old Jul 10, 2011 | 05:19 PM
LawDog88's Avatar
Advance Auto Parts will scan, and clear if needed.
Old Jul 10, 2011 | 05:21 PM
KingMaddog's Avatar
+1 for Advanced Auto Parts. Some places will even give a printout of what the code is and what it means.
Old Jul 10, 2011 | 05:22 PM
LawDog88's Avatar
AutoZone will do printouts, but will NOT clear it.. "Liability" reasons.
Old Jul 10, 2011 | 06:19 PM
Sort of......
There are "cables" available..... Quotated because they are much more than just a cable and come with software for your laptop. Such as my Trifecta setup, that "cable" is a RISC computer that talks to my laptop via USB, it can read and clear codes besides flashing the ECM with a new tune. Pretty sure HP tuners can do the same. This setup would typically run more than a scanner, so if cheap is what you're after this isn't it.
Don't think you will find anything like the dongles from the old days that shorts a couple of pins and honks the horn so many times...... (three short, one long. Etc.) These computers are so much more complex. The above mentioned auto parts houses are your best bet for low cost.
Old Jul 10, 2011 | 06:42 PM
KingMaddog's Avatar
carmd.com it cost 119 bucks.
Old Jul 10, 2011 | 07:29 PM
thumperz's Avatar
no...im taking about like maybe a key dance? like... turn the key 3 time,pause,turn the key 3 more times,then the codes pop up on the gauge cluster display. or press this and that so many times. i know how to for chargers, pt cruisers/neons,older f bodies,f150's... so theres gotta be a free way to pull these codes out in one's own driveway. just wondering if anyone knew. i know about auto zone,and i may or may not but a cheapy scanner for like 20 bucks. but theres gotta be a free way...
Old Jul 10, 2011 | 07:45 PM
The only free way is somebody owns a Scanner Tool and does it for you. Sorry! You must have the scanner tool. The $20 ones may be for the cars that you could "dance" with, so be careful and read the docs! "Electrical Equipment May Not Be Returned" etc.
Old Jul 10, 2011 | 08:00 PM
thumperz's Avatar
Unhappy
damn
oookaa
cjmickel
Feb 4, 2014 06:18 PM
T-Rodius
0
Jul 24, 2012 10:07 AM
stanvalp
Feb 27, 2011 09:29 PM
sunbound
May 25, 2008 08:04 AM
