Electrical problem
Go into both fuse boxes (under hood and to the right on console) and re seat ALL your fuses. I haven't a clue why, but this loosening of fuses is an ongoing problem on the HHR. I had EXACTLY the symptoms you describe. Re-seating the fuses cured the issue. If one is loose several may be therefore press down and make sure they are all seated. I believe this will help you.
For the gentleman below with the "urban legend" comment, I had exactly the same issue with my car and re-seating the fuses solved the issue.
onemancoyote
Jan 29, 2025 05:08 PM
polygurl2003
Feb 20, 2014 10:31 PM
