Thanks Guys,
Its not the radio, as I have tried an Alpine(this one I just didn't like the sound of it), and obviously the stock radio, and now my Sony, now I just need a nice warm day to look behind the radio and the headliner again to see if I can find that "suppose'ed" amp/power wire. And no, not a stubby, I have even tried a 4ft antenna just for the hell of it, still not good. |
Ok, so I tore apart my dash again, I found the pink wire leading up to the base for the amp'ed antenna, hooked it up to the power antenna (+12v) and nothing....some stations it was actually worse.
The funny thing is the stereo converter box I have (that is build for the HHR) when everything is hooked up right, the power antenna or remote from that box DOES NOT get 12volts, It could be faulty but those dang boxes are 80 bucks!!! I used a multi meter on the coax so I know its good. Id rather take my head liner (pain in rear) out again and just re-run the stupid coax, with NO amp, IDK why they did this, a freaking paper clip has better reception! No joke, Although now that I think about it the amp could be for the On Star transmission, not necessarily the reception. |
Originally Posted by yellowjacket
(Post 611557)
Ok, Although now that I think about it the amp could be for the On Star transmission, not necessarily the reception.
Mine had Onstar and there is no antenna at the back :frown:
(Post 611557)
However, the GM FSM says the coax center conductor should be 5 ohms or less from end to end, likewise for the braded shield. With an infinite reading between the center conductor and the braid. Many multi meters are incapable of accurately measuring at this low of a resistance. I would trust no analog multi meter, only a good digital or DVM should be used. |
(Post 611647)
You state that the vehicle did have OnStar, so do you not have any OnStar antenna on the vehicle? If not maybe the previous owner did not understand the needs and tapped into the vehicle radio antenna and that is why you are having such problems. |
Originally Posted by Sno White
(Post 612238)
If there is no OnStar antenna in the rear of the vehicle roof, my bet is the previous owner added some sort of aftermarket unit. So you are not going to get much “good” help here as everybody is assuming a stock vehicle sound system. Sounds like its time for a professional audio shop.
Is a 2008 hhr stock antenna on roof need power ?
I installed a aftermarket radio and get no am and 2 fm stations. From what I have been reading if I have a powered antenna amp this could be my problem. Does any one know if it is and what the voltage would be. I see it may be the pink wire. Thanks in advance.
Yeah..several perps here had gone thru this..the ant is powered and when it fails only the closest stations will come thru..This is how GM got away with a shorty ant, by boosting the signal..you could either add your own amp before the head unit or fix the original..cant help you on the wire colors..
voltage and wire
Thanks as I never hooked any power to the antenna so maybe that is my problem. Didn't know it was powered. If I knewthe voltage and find the wire it may solve my problem. On the radio it has a wire for antenna which I assume it is for the up and down operation. If it would take 12v I could use that if I find the wire. Thanks
