Chevy HHR Network
-   -   engine cooling fan running constantly (https://www.chevyhhr.net/forums/problems-service-repairs-42/engine-cooling-fan-running-constantly-54310/)
Toyoyoye Jul 28, 2015 11:56 AM
engine cooling fan starts running at start up and keeps on running. Pulling relays stops it, then starts on putting it back in. Engine temp reading 185-192 . I'm thinking either relay is stuck in on.? or ECM telling fan to run. any thoughts
Oldblue Jul 28, 2015 12:17 PM
Welcome to the site, is your A/C or defrost turned on? This turns the rad cooling fan on at any temp.
Silverfox Jul 28, 2015 01:34 PM
Doesn't the inside cabin air setting also turn it on ??
SF
donbrew Jul 28, 2015 02:48 PM
Yes, but it resets to fresh air each ignition cycle.
Oldblue Jul 28, 2015 02:53 PM
Yes SF, it does, I forgot that, thanks.
So, OP is you inside cabin air button turned on after you start the HHR?
It does reset to fresh outside air each start cycle
Xkristylynnx Jul 17, 2019 11:28 AM
I'll be replacing the coolant the fans & assembly and thermostat this weekend. No coads no leaks my 2009 hhr ss ran 241 on a 104 hot California day. I'm the 3rd owner I have 105,.... miles wish me luck guys I'm still driving to and from work the temp for the commute is 219
Xkristylynnx Jul 17, 2019 11:34 AM
Pulled radiator cap and it was full hopefully meaning the water pump is working? Other than that I'd next replace to turbo radiator? Since its low to the ground? And I have no ideal what the car has been through before I purchased it but honestly the carfax is 100% the previous owners was great on maintenance and my car is damn near excellent condition inside & out.
Xkristylynnx Jul 17, 2019 11:39 AM
I read that even though the fans r running theres a spot to the computer that burns out? Is this correct?
whopper Jul 17, 2019 11:49 AM
More info on the same problem now posted in a THIRD thread? and no acknowledgement to the already posted advice to the previous postings ?
I'm out.
firemangeorge Jul 17, 2019 12:01 PM
Turbo radiator ? Guess you mean the inter cooler.
FYI. That's for cooling the air going into the intake manifold. Has NOTHING to do with your car running hot.
Quote "I read that even though the fans r running theres a spot to the computer that burns out? Is this correct?"
Sorry, I don't even know what you're trying to say here.
Do yourself a favor and find a good repair shop. Based on your posts, you don't seem to have any mechanical knowledge. You sure don't need to be trying to learn on a SS which is a little more complicated than the average car.
