engine miss no. 1
Old Dec 22, 2010 | 08:33 PM
Don06's Avatar
Valve seat problems might be caused by low octane or methanol. I have a couple of places that sell premium 93 octane fuel without ethanol. I have to have it for lawn equipment and snowblowers and I use it in all my vehicles. My owners manual says to use 91 octane and it can use up to 10% ethanol. Many places have 15 or 20% ethanol with 89 octane. I feel it makes a difference in power and adds about 40 miles to a tankful.
Old Dec 22, 2010 | 11:35 PM
Originally Posted by wifehhr
I did squirt oil in the low cylinder, same 100 lbs compression. Sunoco 93! I really do not think fuel will help. Remember It has 100 lbs of cranking compression. That is misfire territory. I quess that no one has had the same problem. Oh yea, it is driven mostly by my wife to her work which is 45 miles one way on a two lane freeway. Can't get driven better than that. I am the only other driver (our daughter will not drive a "clown car")
Since the compression test did not improve after adding oil.. Then we have to consider the valves & or seats as ChevyMgr pointed out.
Old Dec 23, 2010 | 10:56 PM
wifehhr's Avatar
engine miss
I want to thank all of you for responding to my call for help. I will replace the cylinder head which should bring the compression back to original specs. I would like to also add some power, any ideas. I think I read on here af someone who does reprogramming?
Old Dec 23, 2010 | 11:00 PM
Please let us know for sure if a "valve seat" has come loose.. Inquiring minds need to know..
A "Leak-Down test" is always a great test for further diagnosis..
Tune is best bang for buck imo: https://www.chevyhhr.net/forums/deleted-threads-41/new-chwtunecenter-site-26929/
Old Dec 23, 2010 | 11:23 PM
wifehhr's Avatar
engine miss
Yes I will do a leak down before tearing into it. And yes I will post what I find. Oh, thanks for the link.
Old Dec 23, 2010 | 11:26 PM
Good luck with everything !!
Old Sep 13, 2014 | 11:36 AM
FatTireBiker's Avatar
I know this is a very old thread but I have been experiencing the issues and am thinking of a new head as well. Has anyone else had the problem and is the head replacement been the fix?
Old Sep 13, 2014 | 11:54 AM
Lucky's Avatar
I would think it would be a lot cheaper to do a valve job to your head unless the head is damaged.
Are you having low compression problems?
Old Sep 13, 2014 | 12:01 PM
Yes, in cyl 1as well. My issue is time and I have over 123k on a 2010. In the long run I wonder if the head replacement would be more cost effective
Old Sep 13, 2014 | 12:53 PM
Lucky's Avatar
Unless you find a new head which I'm sure would be pricy you would be looking at rebuilt heads anyway.
If you find a good shop in you area to do the work on your head it may turn out better than a high volume rebuild shop using parts from multiple cyl heads to make one good one.
tooter1
Oct 27, 2014 06:36 AM
kingkat4
Oct 20, 2011 11:20 PM
damronjr
Jan 6, 2010 12:17 AM
CHOLMES
Oct 20, 2009 10:27 PM
dan-d
Apr 7, 2006 04:42 PM
