Engine Temperature Sensor
Old Nov 26, 2014 | 02:16 PM
When you 're changing the t-stat that is most likely your real problem you will notice a brass thingie screwed into the side of the housing with an electrical connector on it, that's it. 12 or 13 mm wrench IIRC.
Old Nov 26, 2014 | 02:26 PM
I'd change out the T-stat with a GM unit, far less problems then worry about the temp sensor, it is most likely just fine!
Old Nov 26, 2014 | 04:31 PM
alshhr's Avatar
no temp guage reading and dic read --------
had this problem few months ago. When I removed thermostat, I found that the built in gasket had been eaten away in spots. Replaced thermostat and all was good with guage and readout from dic. Also disconnected battery for couple of minutes for reset.
Old Feb 13, 2019 | 11:29 AM
Father&son's Avatar
Coolant sensor and a/c not working
If you decide to replace the sensor and t/ stat make sure you spray some electrical spray liquid in the wire harness connecting the sensor. I have the same problems and replaced sensor and t stat many times.
Old Feb 13, 2019 | 11:35 AM
^^^^^^ a very good point, welcome to the site!!
Old Feb 13, 2019 | 04:40 PM
  #26
Cat Man HHR's Avatar
Why? Doesn't the sensor plug have a seal on it ?
Old Feb 13, 2019 | 04:43 PM
  #27
It does but it can still corrode inside were the pins live!
Old Feb 13, 2019 | 08:49 PM
  #28
Mattjones06's Avatar
I still haven’t figured out my problem analog gauge still don’t work but the digital read out works no codes and Yes the AC works. Changed the thermostat and sensor with GM parts.
Old Feb 13, 2019 | 10:32 PM
  #29
You said it moves up when hot ambient. Stop stressing about it, it is of no use anyway.
If you replace the instrument panel it will probably be fixed, pretty expensive, but your sanity is at risk, evidently.
Old Feb 14, 2019 | 10:16 AM
  #30
Your right I let dumb stuff worry me.
