ESC Active flashing
Old Sep 27, 2017 | 10:35 AM
The OP is a female per her info stats page, which has nothing to do with fixing the issues asked about in this thread
Old Sep 27, 2017 | 10:53 AM
chevyhhr09's Avatar
No oil change recently, no brake job. Did get the exhaust pipe welded tho... that was around a month ago... did not do shocks yet... yes, the rear fuel line was replaced a few months ago...
Old Sep 27, 2017 | 10:56 AM
Thanks , so let’s get the battery load tested, it might just be the original one and starting to head south!
Old Sep 27, 2017 | 11:57 AM
Conax's Avatar
I bought a code reader a while back, at Advance Auto parts that reads my 2009 ABS codes. It is an Actron CP9660 PocketScan.
With a coupon I got it for $70.
Good to have with these little robocars.
Old Sep 27, 2017 | 12:22 PM
chevyhhr09's Avatar
Well OldBlue, I got the battery tested and he did it twice.
First time results - good - 75% - need charge
2nd time results - good - 61% - need charge.
He said it looks like the original battery, and it didn't show up on the carfax.
That would make it 8 years old.
Now what? Thank you!!!
Old Sep 27, 2017 | 12:34 PM
Sorry to say but your battery is toast! These little trucklets don’t like a run down electric source. Time for a new battery.
Make sure it is vehicle specific as it is inside and must be vented!
Old Sep 27, 2017 | 12:50 PM
Here's some info on AGM batteries. My original ACDelco group 90 battery went bad nearly 3 years ago. Yours is probably closer to 9 years old.
Old Sep 27, 2017 | 02:01 PM
Carfax only reports what was reported to them. My 2008 was "certified", 6 months after I bought it the almost total accident showed up.
I'm pretty sure the only maintenance that they get is from a dealership service department, not always then Only the deepest of pockets go there.
Old Sep 27, 2017 | 02:47 PM
chevyhhr09's Avatar
So how does the low battery affect the esc system? That can cause this problem?
Old Sep 27, 2017 | 02:53 PM
Low voltage causes many issue with the computer system
