excessive engine vibrations in warmup phase
2011 HHR:
When car goes into warmup phase, vibrations start building up through the steering column - reaches a max about 30 seconds - then drops down to zero. This has been happening ever since I had the car. Dealer says vibrations won't hurt anything - operating normal.
Its not normal, dealer needs to track down what is causing the vibrations, instead of saying, don't worry about it, it won't hurt anything! Just a wild guess, but perhaps its running too rich during warmup. Do you see any black smoke at the tailpipe when its doing the vibration dance?
also forgot to mention that i live in a generally colder climate....the rough starts were ~45 degrees or less which is nearly half the year. lol. in southern states it may not be as noticable but i wouldnt know. if its under warranty it could be worth it to have it looked at. i could be totally wrong assuming its just a cold start thing.
Mine is not excessive vibration or rough idle, or effected much by temperature. mine is a very short, quick vibration that sounds like it originates from side of driver side engine and transfers thru the steering wheel. It is only 1-2 seconds.
I remember reading what I think was a tsb, because the condition was described exact. I believe it was also noted that the buzz was heard in the cabin. It also listed a resolution and thats what I'm looking for.
Well it could be the alt drive belt tensioner per a TSB from way back when.
It could also be a dirty filthy TB blade. Be very careful when cleaning the throttle body
