Exhaust fell apart!
Old Jun 5, 2024 | 07:34 PM
MILESJOHNSSON's Avatar
Exhaust fell apart!
Just got done replacing virtually every piece of my suspension, drove it around, enjoyed the new ride comfort, and then parked it. Went and got gas two days later and then parked it again. Got in it to go to work yesterday, and it sounded like somebody had stolen my catalytic converters. Got under it today to find that the flex end of the catalytic converter section somehow disconnected itself from the clamp that is supposed to hold it on. Has anybody else experienced this? I've already found the replacement part, just have to find a welder who can do it for a reasonable price, since I spent all my money on suspension parts. This was not an attempted cat theft, I have cameras facing it and checked the footage for the weekend.
Photographic evidence.
Old Jun 5, 2024 | 08:29 PM
greg8453's Avatar
You need to replace it. Find bad mounts that allowed it to drop and replace them as well.
Old Jun 5, 2024 | 09:00 PM
A very common failure. There are repair parts available; search ebay "hhr exhaust repair", There are many, I suggest you get one with the bend in it. You will need a welder.
A bad front motor mount is the typical cause. Check it by looking through the oblong hole in the passenger side front wheel well; if a bolt head is easily reachable the mount is good.
Old Jun 5, 2024 | 09:39 PM
Thanks for this advice, I'll check that now. I've already got the replacement part coming from ZZP.
Old Jun 6, 2024 | 07:48 AM
The ZZP part has the bend required for the 2.2 L61, LAP exhaust get that welded up and you’re good to go.
hhrumadbruh
May 7, 2024 03:29 PM
anbishop1
Jul 19, 2016 12:01 PM
jstadtjr
Jul 11, 2015 10:04 AM
solman98
Aug 26, 2013 05:53 AM
whopper
Maintenance and Upkeep
0
Apr 29, 2011 02:08 PM
