Factory Radio Issues
Old Oct 6, 2012 | 09:29 AM
RICKYVB's Avatar
My 2006 HHR I just bought is having a bit of an issue with the factory radio. While I really do not care about the factory radio as I plan on putting the DVD, NAV, Radio I had in my other HHR in. I am curious to see if others are having or had the following issue.
So, when the radio is on. Rear speakers do not work and the front right speaker in the right side passenger door comes on from time to time and cuts out. Now, I tested the speakers and they work 100%. I am guessing it is a Radio problem with channel controls.
Anyone else have this issue with their factory radio? Thanks!
Old Oct 7, 2012 | 10:54 PM
hhrlover101's Avatar
i have a 08 hhr and the same issue is going on with my car its been going on for aat leastt 2 years i have not really looked into it must but it scares the crap outta me when the all work every now and again
Old Oct 9, 2012 | 03:43 PM
oki so i took the dash around the radio and un connected it checkked the connections and pluged it back in and issue still there
Old Oct 9, 2012 | 04:04 PM
SpaceCowboy's Avatar
sounds like a bad amp in the radio
Old Oct 9, 2012 | 05:10 PM
any idea on how much a new one goes for a radio that is
Old Oct 9, 2012 | 06:18 PM
2008LT's Avatar
My 2008 has been doing this since forever.
Old Oct 9, 2012 | 06:58 PM
skyline26's Avatar
this sounds like the same issue I had in my previous vehicle...the speaker cut out would get worse in the colder months..mine had to do with bad wiring throughout the vehicle for the speakers, had to re-wire everything. try swapping the deck and see if it still cuts out
Old Oct 9, 2012 | 08:15 PM
if it is bad wiring it should test ground or open
Old Oct 9, 2012 | 10:59 PM
A Crazy Canuck's Avatar
You can get one at an auto wrecker I'm sure, but they say the theftlock nonsense can make it tough to install.
I would call the dealer about installing a used radio head unit. Then you can see if its not just worth getting an aftermarket bling stereo.
Old Oct 10, 2012 | 07:10 AM
i have a used one out of a 2010 if you are interested
