Front Axle Question
Old Mar 11, 2023 | 12:54 PM
chuckbear's Avatar
Front Axle Question
Had my Panel in the shop a couple of weeks ago and the mechanic showed me how the front axles where the spline goes into the transmission will slide in and out about 1/2 to 3/4 inch when he pulls on it. It doesn't come out completely. So is this normal or do I have a problem? The car drives fine, has no vibration, even up to 85 MPH, and handles great. It has me a bit worried though. Chuck
Old Mar 11, 2023 | 01:06 PM
It’s good, normal for the cv axle movement, it doesn’t move that much when driving.
Old Mar 11, 2023 | 01:21 PM
chuckbear's Avatar
Good to know. Thanks.
Old Mar 11, 2023 | 01:35 PM
No problem, you’re welcome.
Old Mar 11, 2023 | 04:45 PM
That is if you can't see the splines moving. The can on the trans end is a slip joint, the axle can move in and out, not the splines. The splines are supposed to be locked in with circlips.
Old Mar 11, 2023 | 09:48 PM
greg8453's Avatar
When the you hit or go over bumps the axles need to be able to move as the shaft angle changes.
SwaintaN
Jun 14, 2019 04:19 PM
aradmahogany
Jun 14, 2019 10:11 AM
junker
Drivetrain (Excluding Engine)
44
Dec 8, 2017 09:22 AM
Waynejwj
Jul 15, 2013 08:06 PM
JeffsHHR
May 22, 2008 03:24 PM
