Front End Alignment
So My HHR pulls to the right just a tad. I replaced the LCA's with loaded LCA (new bushings and balljoints). It still pulls a tad. I got a front end alignment about 6-8 month ago. It still pulled to the right just a tad, I put new tires on it, it still pulls just a tad. I am gonna get another front end alignment from a different shop, getting the lifetime warranty which I should have gotten the first time. Got any advice.
The camber(lean) of the road surface can make cars "appear" that they're pulling to one side a little. The interstates around here lean right in the right lane and left in the left lane. They'll pull you that way depending on the lane you're in.
I drove from Dallas to Houston (4 Hours) and then back (another 4 hours). It is driving me crazy.
We have the same road tilt in Ohio I get the same results |
You really can only adjust the toe, now you can check it yourself, but I would take it to a competent shop. |
Originally Posted by Oldblue
(Post 858151)
You really can only adjust the toe, now you can check it yourself, but I would take it to a competent shop. https://cimg9.ibsrv.net/gimg/www.che...f40878a4f0.jpg |
I'm not sure how effective camber bolts are on our rigs, but I know they make them for the HHR's. And to be perfectly honest, I never understood what caster was.
(Post 858151)
You really can only adjust the toe, now you can check it yourself, but I would take it to a competent shop. agree..... |
here's an example of what i mean by the elongated lower bolt hole...this strut's not for the HHR but it illustrates how the struts looked that i put on mine...
https://autoplicity.com/9459049-monr...nt=All%20Items |
