Front End Alignment
Old Dec 31, 2018 | 04:53 PM
guppy's Avatar
Front End Alignment
So My HHR pulls to the right just a tad. I replaced the LCA's with loaded LCA (new bushings and balljoints). It still pulls a tad. I got a front end alignment about 6-8 month ago. It still pulled to the right just a tad, I put new tires on it, it still pulls just a tad. I am gonna get another front end alignment from a different shop, getting the lifetime warranty which I should have gotten the first time. Got any advice.
Old Dec 31, 2018 | 05:00 PM
The camber(lean) of the road surface can make cars "appear" that they're pulling to one side a little. The interstates around here lean right in the right lane and left in the left lane. They'll pull you that way depending on the lane you're in.
Old Dec 31, 2018 | 05:13 PM
guppy's Avatar
I drove from Dallas to Houston (4 Hours) and then back (another 4 hours). It is driving me crazy.
Old Dec 31, 2018 | 08:09 PM
Chrris F's Avatar
We have the same road tilt in Ohio I get the same results
Old Dec 31, 2018 | 08:24 PM
You really can only adjust the toe, now you can check it yourself, but I would take it to a competent shop.
Old Dec 31, 2018 | 08:33 PM
guppy's Avatar
Old Dec 31, 2018 | 08:34 PM
guppy's Avatar
I'm not sure how effective camber bolts are on our rigs, but I know they make them for the HHR's. And to be perfectly honest, I never understood what caster was.
Old Dec 31, 2018 | 08:38 PM
alexrckid's Avatar
only the toe can be adjusted by a shop....if you're the original owner and/or know that the chassis has never been "tweeked" by an accident, a good front end shop can adjust the camber, ever so slightly, by loosening the two bolts on the bottom of the strut.....most of the after market struts have elongated slots where these bolts go....let the shop know about this...they can pull the camber into specs if it's out of specs......worked for me with the Monroe loaded struts that i put on awhile back.......
agree.....
Old Dec 31, 2018 | 08:43 PM
alexrckid's Avatar
here's an example of what i mean by the elongated lower bolt hole...this strut's not for the HHR but it illustrates how the struts looked that i put on mine...
https://autoplicity.com/9459049-monr...nt=All%20Items
Old Dec 31, 2018 | 08:48 PM
alexrckid's Avatar
for your Caster question..
