Front suspension components replacement
Old Dec 15, 2017 | 09:48 PM
slonny's Avatar
I am considering replacing front struts and stabilizer links. Is it a good idea to change sway bar bushings as well while I am at it or should I wait until they are completely worn out?
The car has 95,000 mi on it with stock components. Nothing is clanking or leaking. I suspect the struts are pretty much at the end of their life time, even though they are not showing any leaks.
Old Dec 16, 2017 | 12:44 AM
If they are worn, replace them - it's easy enough to check by prying with a lever to see if there is movement within the bushing. If there is no noise, I suspect that are ok. Worn sway bar bushings are fairly noticeable.
Old Dec 16, 2017 | 07:32 AM
For the price, replace them.
Old Dec 22, 2017 | 10:35 PM
prod's Avatar
Chances are the control arm bushings are worse off, you want to check them for excess movement while the struts are out.
EDIT: Nevermind, I see you have another thread on the control arms.
whopper
Jul 16, 2014 03:40 PM
JBP
May 4, 2009 10:22 AM
hvrod
Aug 7, 2007 03:32 PM
