Fuel Pressure Test Procedure
Old Aug 16, 2012 | 05:41 PM
guyfromblaine's Avatar
Hi
we have a 2008 2.2 that my wife named Henry.
Henry has a problem starting up. He takes a long time to start, or it takes two tries. I have looked at other posts about this and have done the inexpensive stuff. I think that this is likely a fuel pump issue.
I want to run a Fuel Pressure test to confirm this before I spend approx $300 on a fuel pump and drop the gas tank to install it.
I can get pressure gauges from the parts store on a very inexpensive rental. However the procedure in Alldata says that to run this test you need to turn on the fuel pump relay when the engine is not running usually multiple times. You then time the pressure drop and compare against the specs. My code scanner will not turn on the fuel pump, neither will the one I can rent at the parts store.
Does anyone have a suggestion on how to do this on the cheap ie a scanner/analyzer/software package that does not cost a more than a shop would charge to run the test for me? Or, a procedure to start the fuel pump without frying the electronics?
My honest job just ended, so I need to do this as inexpensively as possible.
I appreciate any advice you can give.
Old Aug 16, 2012 | 05:46 PM
ChevyMgr's Avatar
Miles? Delivery date?
Old Aug 16, 2012 | 05:54 PM
one more thing about Henry
Henry's check engine is not lit and there are no diagnostic codes when I scan his computer.
thanks again
Old Aug 16, 2012 | 05:56 PM
Henry has 91,000 miles
I have my wife driving my car now. I have some time to get this done, as I am now retired/unemployed...
Old Aug 16, 2012 | 06:00 PM
The car was purchased used from a local Chev dealer. The car is out of warranty, as a fuel pump is not power train. I called the dealer and checked.
Old Aug 16, 2012 | 06:08 PM
oneton's Avatar
Install fuel press gage turn key to run not start, wait 3-5sec turn off wait 5-7sec turn to run ect. Each time you cycle the key it will turn the fuel pump on for 2 sec. So you can prime the gage. you can start the car with gage installed also.
Old Aug 16, 2012 | 06:21 PM
ChevyMgr's Avatar
Fuel pump IS powertrain on a 2008. Send me a message with the last 8 of your VIN and I will check the delivery date. You may still be in warranty.
Old Aug 16, 2012 | 07:00 PM
ChevyMgr's Avatar
Your delivery date is 9/18/2007. Your fuel pump is covered until 9/18/2012. Fix is free.
Old Aug 17, 2012 | 12:06 AM
Well, that is cutting it close.. Wonder if OP will ever respond ?
Old Aug 18, 2012 | 05:25 PM
Thanks for the info
I have an appointment with service at the dealer on Monday
I will post the outcome after that.
cheers
