Gauges going up and down
Old Dec 27, 2019 | 02:08 PM
Kristinmg488's Avatar
No i am not the original owner. I bought this in March of this year. It is an LT with 152755 miles. I dont think he erased the codes. Sometimes my thermostat gauge does not work, most of the time it does.
Old Dec 27, 2019 | 02:41 PM
Cat Man HHR's Avatar
If you can erase the codes it would help.
You might have old codes that were a problem when you didn't own the car and they were repaired.
Old Dec 27, 2019 | 02:47 PM
Okay I will have that done.
Old Dec 27, 2019 | 03:12 PM
The idiot that said ECM didn't know what P0700 means. Those codes indicate a fault on the CAN bus; a bad wire on the computer network.
I would bet there is a broken wire or connector, probably on the TCM.
Replace the t-stat with a ACDelco 131-158 ONLY to fix P0128.
Old Dec 27, 2019 | 08:53 PM
This shows the codes, but where’s the report printout of the battery voltage and CCA’s .
I’ve been in the short end of one of those guys telling me the battery was fine, it died two days later while on vacation in Florida, and he said the cars only four years old , don’t worry about it!
Old Dec 27, 2019 | 08:59 PM
Replace the thermostat yourself, as Donbrew says only use an AC Delco 131-158 180 degree thermostat
https://www.chevyhhr.net/forums/how-...l-p0128-24493/
and burp the coolant system
https://www.chevyhhr.net/forums/how-...-system-60614/
and the ground wires are down to the right of the oil filter on the transmission case then check the TCM it is under the plastic shield just near the fuse box with the blue terminal connector
Old Dec 27, 2019 | 09:59 PM
Okay great! I will let you know how I make out with it. Thanks!
Old Jan 3, 2020 | 06:14 PM
royl's Avatar
I read somewhere on here about oil migrating up the wires from the engine area into the TCM plug. When my 07 starting acting like you described I pulled the plugs from the computers under the darth vader cap it sure enough had oil in one of the plugs. I cleaned it out numerous times with alcohol and compressed air. It has not reoccured since and I have taken two long trips in it since then. Maybe a cheap easy fix for you too.
Old Jan 6, 2020 | 08:29 PM
So far I have had someone clean the grounds, but that didnt work. I will have him try that and see what happens! Thank you!
Old May 28, 2020 | 06:56 PM
Deanna Kelly's Avatar
Every couple of days, my HHRs gauges will all go up and down several times, the security light comes on, sometimes the check engine light will come on, and I get a power steering warning too. This lasts for a few minutes and then usually quits. Sometimes while its doing this it will shift really hard too and it feels like it has no power. Anybody know what would be causing this?
As crazy as this might seem. My HHR was doing the same thing. And I removed the fuse cover in the passenger floor board and it went back to running normal
