gurgle
Old Oct 8, 2010 | 08:57 PM
Jeda13's Avatar
gurgle
I'm sure this had been dissected a thousand times... Can someone link me to a thread that explains why I hear a gurgle sound in my dash upon start-up? 2008 SS.
JIm
Old Oct 8, 2010 | 09:10 PM
windsmith's Avatar
Air in the cooling system / low coolant level.
Old Oct 8, 2010 | 09:57 PM
Jeda13's Avatar
Fix?
Old Oct 9, 2010 | 12:09 AM
park where the front end is higher than the rear, air will usually travel to the highest point. & you may have to add coolant.
Old Oct 9, 2010 | 08:16 AM
windsmith's Avatar
The big question is - how did the air get IN there? Check for water in the oil, and higher than normal engine temps. I've been reading quite a few posts about blown head gaskets.
Old Oct 9, 2010 | 10:17 AM
ChevyMgr's Avatar
Fix = pressure test system to find the leak. Most likely covered by warranty.
Old Oct 10, 2010 | 12:02 PM
Randy_W's Avatar
Mine does i8t some, my '05 Grand Prix did it all the time, it was never low on coolant and I bled it a bunch of times, didn't change at all. It's not that uncommon in a bunch of vehicles as a couple of my Tahoes did it as well.
Old Oct 10, 2010 | 06:54 PM
Don06's Avatar
Is it the heater or the ac system. The tank for the ac holds pressure and it equalizes through an orifice into the evaporator which could cause a gurgling sound.
paulBvtn
Apr 6, 2012 11:23 PM
