Heat gauge and AC not working all of a sudden
Old Jul 3, 2010 | 05:44 PM
JuMPy's Avatar
Originally Posted by ChevyMgr
A bad coolant temperature sensor could cause the gauge to be inop and since there would be no temperature reading to the BCM, it would command the A/C to not come on.
Where is it located?
Old Jul 5, 2010 | 07:01 AM
JuMPy's Avatar
OK, so this morning I'm off to go to work, and take the car in. The heat gauge pops back up after about 5 minutes of driving, and the AC starts working. On the hiway won't go over 78C (normally ran at 88C dead set and hardly wondered). Get into traffic and it starts to climb. Hit 90C before I decided to get off the hiway and keep moving. Got to work, and let it sit (all the way up to 93C) to come up. The Fan won't turn on now to cool it down! Clearly the T-stat is buggered hence the low temps....but now the fan going AWOL bothers me.
Old Jul 5, 2010 | 09:05 AM
See the previously posted links on thermostat problems And how to replace it. Fan operation at 93 is normal.
Old Jul 5, 2010 | 12:54 PM
JuMPy's Avatar
T-stat changed...all is well
Old Jul 5, 2010 | 12:56 PM
Glad you found the problem......
Old Jul 6, 2010 | 06:15 AM
JuMPy's Avatar
OK...maybe not "all" is well. Keeping a close eye on things, turns out the cooling fan only turns on if the AC is on. Without AC on, the temp keeps climbing. I didn't let it go above 100C. Once I flicked the AC on, the fan came on, and the temp dropped.
Might also explain why the T-stat failed in the first place.
Now, I have to try and figure out why this is happening ...... joys of high mileage cars
Old Jul 6, 2010 | 06:34 AM
pitbull76's Avatar
100C should be no problem (that's 212F, right?) On my SS, the cooling fan doesn't kick on until 216F if I remember right so yours is probably fine. I know that sounds high, but it is a pressurized system. It isn't overheating at that temp and the coolant won't boil till quite a bit higher temps.
Old Jul 6, 2010 | 06:37 AM
Yeah.... I think you are seeing normal operation there......
Old Jul 6, 2010 | 07:30 AM
JuMPy's Avatar
It always turned on before that, it used to fire up and keep engine temp square at 88C with AC on or not.
Keep in mind I say 100C before I flicked the AC on to turn the fan on. Otherwise I have not gotten the cooling fan to come on without AC on. I can try to let it go a little higher, but as I mentioned, it never did this before. My guess is something is messed with it.
Old Jul 6, 2010 | 08:40 AM
JuMPy's Avatar
comes on at 103 .... guess I never noticed it before. Learn something new everyday
....now, off to change my stablizer links ...... again
