Heated seats switch blinking
Hey Guys I done the search now I'm cross eyed, Can someone point in the direction of replacing a module or element in the seat 2006 HHR LT, I'd like to do the repair myself and get this heated seat back in operation.
I don't think there is a how-to on that process here.
If you aren't sure where the problem lay, you need to do a little problem diagnosis. I'd start with checking the resistance of the heating element - if it's "open" then the heating element needs replacing. You can also check for voltage being supplied to the heating element.
If you end up replacing the heating element, I'm sure some here would find it handy if you documented the process.
Youtube has a few videos you can checkout as well - ie:
Check the search again, somebody did post recently with pics about doing the seat thing. Maybe you just aren't guessing at the right search phrase. You are using the SEARCH box at the top of this page? I just did a 800 mile day and don't feel like looking right now.
