Heater blows cold
Old Dec 10, 2017 | 01:27 PM
  #71
A control panel used isn’t that much
https://www.ebay.com/p/07-08-09-10-1...ater/835689034
Old Dec 10, 2017 | 01:37 PM
  #72
Cat Man HHR's Avatar
Don't know the logic how the control panel works. I'm guessing the heat level dial is a variable resistor that would send info to the control valve via maybe the BCM?
It was said early that the heat fluctuated no matter where the air was coming out of, floor or windshield.
Old Dec 10, 2017 | 01:45 PM
  #73
I concur , I don’t believe this to be the control panel, more likely air in the system or head gasket
Old Dec 10, 2017 | 01:51 PM
  #74
Jlogudce's Avatar
Ok......earlier this morning I started the car, saw the actuator go to the hot side and the heater got warm. I will monitor it over the next day or two and see if the coolant level goes down and the heater stops working.
Old Dec 10, 2017 | 01:54 PM
  #75
Alright, now keep us posted please.
Old Dec 10, 2017 | 01:56 PM
  #76
Thanks as this is interesting. Your finding out the problem will help other people with this issue.
Old Dec 10, 2017 | 05:51 PM
  #77
I don’t recall any mention of the symptoms of a blown head gasket in the thread
Overheating
White smoke out the tailpipe
https://gobdp.com/blog/how-can-i-che...n-head-gasket/
So I’m still thinking burp that baby!!
Old Dec 12, 2017 | 07:17 PM
  #78
db2006's Avatar
How would air in the system cause the blend door to move? Once the control is set, the blend door should stay in position. Full heat is full heat. HHRs don't have automatic temperature control.
I would take the connector off the blend door and lock it in position. If the heater continues to blow hot air, the problem is not in the cooling system. If the actuator is a motor, it should stay in position with the electrical disconnected. If it does, something is sending power to move it.
Old Dec 13, 2017 | 07:45 AM
  #79
aradmahogany's Avatar
Because heat is transferred to the cabin by pulling air through the heater core when its full of HOT WATER. You cant get hot air in the cabin if there is no hot water in the heater core, believe it or not. Since the core is highest point of cooling system, if the system is low or leaking (or has an air bubble trapped in the heater core), you wont have enough coolant running through the heater core, thus no hot air!
Old Dec 13, 2017 | 09:05 AM
  #80
Correct, and once we’ve determined the coolant level and reason it’s low, we’re gonna examine the blend doors and their actuators
