Help with HHR 06 ls
Old Feb 16, 2014 | 08:26 AM
Frisk's Avatar
Help with HHR 06 ls
Having a few problems when stopping, wants to go dead on me. New battery, new spark plugs acts like a vacuum leak.
Could someone suggest fix for the rough idling and going dead at traffic lights, missing when trying to take off, will not go into passing gear, runs fine on the road just stop and go!
Thanks
Old Feb 16, 2014 | 08:33 AM
Welcome to the site. Has it displayed a code, running that bad it must have a code or four.
Old Feb 16, 2014 | 08:54 AM
Frisk's Avatar
the parts place oreilly's that checked it did not give a code, just told me it wasn't electrical. I'm to old to know everything that I should thanks for asking.
Old Feb 16, 2014 | 09:15 AM
Frisk's Avatar
If anyone has any solutions to my little problem feel free to write me @ xxxxxxxxxxx, thank you very much!
Old Feb 16, 2014 | 10:25 AM
So you had it checked. Is this because the Check Engine Light(CEL) was on?
If it was on, there should be an active code # or stored code that shows up with a scanner.
Be advised, that not all "parts places" are good at reading codes. Some just plug in a scanner and read it. You need one that can read the code AND decipher what it shows.
If possible, have it rescanned and post up any trouble codes here. We would love to help you if you can get the code numbers.
AND, be sure to get the actual code numbers that look like P0001,P0010, etc.
Getting just the description of a code does no good.
As far as a suggestion to what's wrong, it would be a waste to try and guess.
Way too many different things that could caused the problem you described.
Old Feb 16, 2014 | 10:38 AM
I edited the email address out to save you a lot of grief from spammers. It is real bad policy to openly publish personal stuff like that.
