Help needed - Scanner code, locate camshaft position sensor
Old Mar 1, 2011 | 10:22 AM
jojo33's Avatar
I used the CAN OBDll scanner and got codes P0010 and P0011 which said that I need to replace the camshaft position sensor. I ordered the part from Napa Auto and will receive it tomorrow. I would like to know where the camshaft position sensor is located. From what I have seen on the previous messages posted is for the intake and exhaust solenoids. Any help would be much appreciated.
Old Mar 1, 2011 | 11:16 AM
Snoopy's Avatar
Just checking....
Did you see this stickey.....
https://www.chevyhhr.net/forums/show...osition+sensor
Old Mar 1, 2011 | 11:48 AM
jojo33's Avatar
Yes, but it shows the intake and exhaust cam solenoids. Is this the same as the camshaft position sensor?
Old Mar 1, 2011 | 11:52 AM
Snoopy's Avatar
I would think so....that's what Whopper's title says!!
maybe someone else can answer...or even Whopper.
Old Mar 1, 2011 | 12:54 PM
If you are getting P0010 and p0011, then I would expect you will need to replace the
Camshaft Postition Actuator Solenoids -
From chevyMgr's listing of the various codes at https://www.chevyhhr.net/forums/problems-service-repairs-42/list-diagnostic-trouble-codes-2008-2010-hhr-14259/ :
P0010 Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit
and 0012 is for the Exhaust.
Snoopy's post has a pointer to the re and re process, including the part numbers/prices for my 2006.
Hope that helps man. Keep us posted
ps: if you are going to replace one of the solenoids, I'd recommend replacing them both - what the heck, they aren't that much $'s and why take it apart again for the other one down the road. Save the good one you pull out for a spare :)
Old Mar 1, 2011 | 12:56 PM
Snoopy's Avatar
Thanks for catching up, whopper !!
Old Mar 1, 2011 | 03:54 PM
jojo33's Avatar
Snoopy and Whopper:
Thanks for the updated information.
I will receive part tomorrow and will begin working on the car. Hope all goes okay.
Old Mar 5, 2011 | 01:30 PM
jojo33's Avatar
Cool Job Done!
To Whopper and Snoopy,
Got the job done this morning. It took about 40 minutes and was very simple.
Thanks for all the info that you gave in helping me out.
Jojo
Old Mar 5, 2011 | 01:33 PM
Snoopy's Avatar
Mostly, the thanks goes to Whopper. He provided the "how-to", I just pointed you in that direction.
I trust everything is running correctly!!!
Old Mar 11, 2011 | 03:32 PM
You be most welcome. Hopefully that cured the problem?
