Help please
Old Sep 12, 2020 | 06:12 PM
Deiseltech's Avatar
I have 2011 hhr if I start it after its set over night or sets for 3 or 4 hours it starts and runs fine for about 5 seconds then the engine starts missing like it revs up and down for about 10 or 15 seconds then clears up and able to drive it but it acts like something is holding it back loses power I've changed upstream o2 sensor put new throttle body on put new speed sensor and maf sensor still getting cil and code system too lean bank one any ideas of what my problem is
Old Sep 12, 2020 | 06:19 PM
Welcome to the site, please post the codes you’re getting, just the codes, we can take it from there.
Old Sep 12, 2020 | 06:48 PM
Deiseltech's Avatar
P0172 and p0455
Old Sep 12, 2020 | 10:44 PM
The P0455 is most likely the EVAP vent valve (behind the gas tank).
You probably have a bad fuel pump. It should hold pressure. You may have a rusted out vapor return line
Old Sep 13, 2020 | 08:21 AM
https://www.obd-codes.com/p0172
points to the MAF sensor, check to ensure the connector is seated firmly in place.
https://www.obd-codes.com/p0455
points to the EVAP system has a leak, somewhere, most likely the purge canister valve , but do check the purge vent valve under the hood . You should not be able to blow air through it from grey side to black side. Even a little bit can cause starting troubles.
Old Sep 14, 2020 | 12:45 AM
Deiseltech's Avatar
The o455 code came up bc the gas cap but when I bought the car the check engine light was on said system too lean I changed o2 sensor (upstream) now it says to rich any ideas
Old Sep 14, 2020 | 08:34 AM
Yes, reread post #5 .
Old Sep 14, 2020 | 08:38 AM
Yes, read the previous post.
The codes actually are "fuel TRIM too rich"; that means the computer is adding fuel because the fuel ratio is too lean.
Old Sep 14, 2020 | 08:52 AM
Which the MAF sensor is responsible for reading and adjusting.
Old Sep 14, 2020 | 08:53 AM
Are you using an oiled air filter? (K&N, etc)
Inspect the flex pipe for cracks.
