HELP! w/Fender & Running board adjustments
Old Jul 31, 2009 | 03:25 PM
PhxHHR's Avatar
Howdy, all: For any of you who can help with the following, I'd greatly appreciate it. Been a member here for several years, shortly after purchasing my '06 HHR 2LT in October '05:
Travelling down the freeway yesterday, I lost the outer layer of my front, driver's side tire - the entire belt just flew off, causing minor damage to my front left fender and driver's side running board. It's in the shop today getting new tires and an alignment, but I need y'all's help with the following:
- Where and how are the fender and running boards attached to the body? I'd like to try and adjust them back into place, if possible. I'm a bit handy with tools, but have never ventured into trying to fix auto body parts. More than anything, the fender and running board need to be tweaked back into place, but I'm at a loss as to how they are even attached.
THANKS MUCH in advance for your assistance - it is much appreciated.
Old Jul 31, 2009 | 03:30 PM
2006blkcobaltss/sc's Avatar
if possible can you take pics of how far out of alignment ?
is the miss alightment on the fender at the top or bottom of the fender ?
as for the running boards i am not sure as my moms hhr does not have them
Old Jul 31, 2009 | 04:09 PM
PhxHHR's Avatar
Originally Posted by 2006blkcobaltss/sc
if possible can you take pics of how far out of alignment ? is the miss alightment on the fender at the top or bottom of the fender ? as for the running boards i am not sure as my moms hhr does not have them
I'm getting it back today (I hope), and will post more info and pics, if possible. Thanks!
Old Aug 1, 2009 | 12:45 AM
Theresa has got a couple of pics that show where the boards are attached in her write up on installing the boards...........
https://www.chevyhhr.net/forums/how-tutorial-library-21/installing-running-boards-womans-viewpoint-5750/
Old Aug 1, 2009 | 08:35 PM
PhxHHR's Avatar
Thanks for the tips so far, y'all - I got the Hispanic Hot Rod home yesterday, complete with new tires all the way around. I fiddled with the fender and the running board that had come loose, with the following results: I got the running board back in place, and the front left fender has also been put back in place. The only remaining issue is a slight gap between the front bumper, which wraps around and connects to the front left fender, and the front left fender itself. It's a minor gap, but a gap nonetheless - I took it all apart yesterday, but cannot seem to figure out how to fix this slight tweak, unfortunately. I shall keep trying -
Dennis Puskar
Sep 20, 2012 10:30 PM
VictorySpark08
Jan 10, 2009 12:27 PM
sjssk
Apr 25, 2007 09:45 AM
blackout
Jul 20, 2006 11:16 PM
