Help-what have i done?
Old Aug 10, 2010 | 02:51 PM
ChevyMgr's Avatar
Originally Posted by foolmoon_design
Wasn't XXL experiencing the same problem before he was banned?
XXL wasn't banned.
Old Aug 10, 2010 | 02:52 PM
ChevyMgr's Avatar
Since your problem started when you removed the cluster and put back in, maybe you should be looking at the pins in the cluster connector.
Old Aug 10, 2010 | 03:02 PM
bjall4jc's Avatar
Checked the pins. They all loooked great. I'm going to try and trace the wires down from the multi-pin connector, and see if there are any bare wires down that cluster of wires.
Old Aug 10, 2010 | 03:34 PM
Peanut oil????
Old Aug 10, 2010 | 03:42 PM
Putter's Avatar
Dude...you need hamsters. NOT mice. Doh!
Old Aug 10, 2010 | 04:43 PM
ChevyMgr's Avatar
Hamsters drive KIAs
Old Aug 10, 2010 | 10:12 PM
bjall4jc's Avatar
I've traced the problem back to the gauge cluster. As of right now, I'm suspecting a bad solder joint, or an accidental cross solder. The dealer is still testing and will let me know. If it was my LED's, I get to pay for a new cluster, if it is something bad in the cluster, GM gets to pay for it.
Old Aug 11, 2010 | 02:34 PM
bjall4jc's Avatar
Ok, prepare to laugh a little bit. The aftermarket moonroof that the dealership had installed before I bought the car, had the power wire and grounding wires tied into part of the gauge cluster. The dealership was able to re-run the wires to the fuse block and properly power, and ground out the wires as needed. They ended up replacing the gauge cluster because when they took it out, they ended up grounding out the power wire and fried it.
Long story short, new gauge cluster=fixed car.
I'm a happy customer.
Old Aug 11, 2010 | 02:53 PM
09 Silver Bullett's Avatar
You should go buy a lottery ticket.
Old Aug 11, 2010 | 02:57 PM
bjall4jc's Avatar
OoH. thats a great Idea.
