Chevy HHR Network
-   -   HHR dead again (https://www.chevyhhr.net/forums/problems-service-repairs-42/hhr-dead-again-49409/)
jack kelly Feb 2, 2014 06:37 PM
HHR dead again
Please help. Have installed two new fuel pumps as per chevy. Car still dead. have found loose connection at UBEC harness, female clip is broken. please what is the part number and name of female clip on wiring harness that goes into bottom of fuse block-female clip pushed out and broken, not sending power to fuel pump- pushed back in place (temporary fix) and the car started and run just fine.
Lucky Feb 2, 2014 07:00 PM
I needed the same type of pin for the fuse box connector when I installed fog lights.
I could not find anyone to supply me with one not even the dealer.
I used a standard female spayed terminal and used RTV sealer squirted it into the connector around the pin to hold it from getting pulled out.
Another option would be to find a connector from a junk yard and reuse one of the pins
843de Feb 3, 2014 12:33 AM
Sorry to say Jack, but Lucky hit the nail on the head.
That connector is made of pure "Unobtainium", it's just not available.
Either go Lucky's route, or find a local salvage yard with some vehicles built on GM's Delta platform like the HHR, Cobalt, G-5, Ion, or SAAB 9-3. Then try to salvage a connector from one of them.
jack kelly Feb 9, 2014 08:14 PM
got hhr running . fixed broken clip in under hood fuse block. runs like champ now.
thanks for the input. now does anyone know what fuel rail pressure gauge to use on a 2.2
Lucky Feb 9, 2014 09:03 PM
Use a standard fuel injection gauge 0 to 100 psi
Lucky Feb 9, 2014 09:07 PM
1 Attachment(s)
Most parts store sell them and some rent them.
jack kelly Feb 10, 2014 09:17 AM
i was not very clear about the gauge. i meant a permanent install one just to leave on.
firemangeorge Feb 10, 2014 02:53 PM
If it was a SS, that 100 psi gauge wouldn't even come close. :lol:
The SS high pressure fuel pump can put out some serious fuel pressure numbers. Check out this RPD shot from my car at startup.
Attachment 15780
Lucky Feb 11, 2014 12:03 AM
There are lost of options for gauges. Look at summit racings web site. Also a very cool place to put the gauge is to get a pillar off of an ss and mount it on the post it will look factory.
A new one is expensive but you can find them use from time to time
