hhr dies at stop signs
Old Jan 19, 2011 | 01:10 AM
duluth_hhr's Avatar
I have a 2006 hhr and in cold weather it will start just fine and after warming it up for a little bit it will drive but once I have to stop at a stop sign or stop light the rpms will fluctuate a little and then the car will die. I've had it into two mechanics and they can't pinpoint exactly what is causing this so they cleaned the mass air flow sensor and replaced the throttle body actuator...it still dies but every time it starts right back up. What else could it be???
Old Jan 19, 2011 | 05:31 AM
Have you been able to rule out a bad tank of gas?
Old Jan 19, 2011 | 08:45 AM
duluth_hhr's Avatar
Yes...it's an ongoing problem it only happens in cold weather...it started happening last winter and it's still happening...last winter I did fuel treatments and heet...all fluid levels are normal and changed on schedule
Old Jan 19, 2011 | 08:51 AM
jay loukakis's Avatar
any codes?
have you checked the plugs or changed them?, good luck.
Old Jan 19, 2011 | 12:08 PM
mrsilent13's Avatar
so when you hit the brake it turns off...could a be some kind of vacuum leak in the brake booster?
id have to see it to actually diagnose it...but the brake booster seems like it could do that if the leak was big enough
SwissHHR
Sep 8, 2015 10:47 AM
yrrah
Nov 15, 2013 08:41 AM
Jul 23, 2008 01:05 PM
