HHR stalled then wont start back up.
The ECM does not "control" the sensors, for the most part they are passive coils of wire. More likely a loose connection, a frayed wire or a blown fuse than a bad sensor or computer. The computer only reads data and adjusts things; garbage in, garbage out.
If you are changing the timing chain, install a replacement bolt in the front guide upper bolt .
https://www.chevyhhr.net/forums/how-...in-kits-60394/
https://www.chevyhhr.net/forums/how-...de-bolt-62897/
Back in 2008 ChevyMgr posted a list of C and P codes for HHR. The descriptions for P0016/17 (wisely) do not include the word sensor there.
- P0016 Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation
- P0017 Crankshaft Position (CKP)-Exhaust Camshaft Position (CMP) Correlation
But all over the web they do use the word sensor, apparently causing massive confusion. Here’s a more lucid one: “The correlation of the camshaft and crankshaft positions on bank 1 is incorrect based on the intake camshaft position sensor..”
For the life of me I don’t know why people conclude that that means a sensor is bad. How could the computer know the correlation is wrong unless the sensors are working? Surely tens of thousands of sensors are pointlessly replaced because of this confusion.
Ref: https://www.chevyhhr.net/forums/prob...010-hhr-14259/
OK, it was only P0016. But since it now won’t even start, the chain has jumped more than the one tooth or two that just made it run bad. I would not decide on a complete chain job until I knew if the valves have crashed. I’m not sure how to do that. Oil on one plug? Maybe just bite the bullet and pull the head.
It is plausible that gummed up VVT solenoid valves or actuators could cause a P0016/17, but really rough running is surely a jumped chain, and a crank no start could mean it’s too late for just a chain job.
I think GM should reflash all EcoTec ECM’s so that a P0016 or 17 goes to an immediate flashing CEL and won’t allow the engine to be cranked if a restart is attempted.
