Higher Coolant Temperature
Order the 180 degree AC Delco thermostat, not the $14.95 professional, this one
http://www.jcwhitney.com/p3042205/sku-3503285.jcwx
Hey fast, read through some forums and you will find that your temperature is within the normal range, and all the situations you described are 100% normal. No need to worry. Analog doesn't move much. In fact, if you are bored enough and watch it, it doesn't even rise gradually it "jumps" from spot to spot. Your digital readout is fine
Well, now I noticed that the coolant temperature was going up slower than usual after starting it. I was suspecting a stuck open thermostat, and then a few days later I got he usual --- digital readout, no analog gauge reading, and eventually P0128. So maybe my original problem with erratic higher temperatures was a failing thermostat.
Looks like I will be replacing the thermostat soon. This is a new AC Delco from Rock Auto that I installed in January. It was probably the "AC Delco professional" model rather than the one that oldblue recommends (AC Delco 131158 OEM model).
So what is so special about the OEM 180 degree thermostat over the professional 180 degree thermostat? So now even AC Delco makes a cheaper "crappy" part also? I still can't believe a thermostat costs so much ($31 !!! at Rock Auto).
Steve
Steve
