Horn blasts on its own unexpectedly
Old Oct 24, 2018 | 01:08 PM
Barb O.'s Avatar
Horn will blow while turning or in reverse. Not an alarm, but a solid blast. A couple times, it went for about about a minute, then stopped on it's own. Pulled the fuse and relay for now. Could one be going bad?
Had the Signal Arm replaced. Using aftermarket fob.
Old Oct 24, 2018 | 01:46 PM
Welcome to the site, it could be the horn is toast, it could be the clock spring, it could be the fuse box halves loose.
Old Oct 24, 2018 | 02:27 PM
After market fob implies after market anti-theft system, if so that is a problem for whoever installed it.
Old Oct 24, 2018 | 02:31 PM
Barb O.'s Avatar
No, original fob broke and I didn't buy an OEM one. It was programmed at the dealership. It was working fine, I don't think the horn issue is related to it unless it was triggering the alarm system.
Old Oct 24, 2018 | 03:19 PM
Could be the horn ring is worn. That is under the airbag, maybe the airbag mount is broken allowing the switch to make contact. Only other thing I can think of is a very odd fault in the horn relay.
Old Oct 24, 2018 | 04:29 PM
Barb O.'s Avatar
Looking at the symptoms of a bad clock spring in the steering/airbag assembly, including a rubbing sound occasionally when turning, I think that's the culprit. Thanks for all the great feedback.
Old Oct 24, 2018 | 05:34 PM
Dorman has a replacement clock spring, RockAuto carries it, and they have a video how to
https://www.rockauto.com/en/catalog/...ckspring,10480
Old Oct 24, 2018 | 06:28 PM
No need to pay anyone to do it if you have a screwdriver and some sort of ice pick thingy. Just pull the airbg fuse 30 minutes before you start work. This how to shows how to get to it. https://www.chevyhhr.net/forums/how-...ng-wheel-1912/
jwhorner
Dec 1, 2011 07:47 PM
RHHRTOYPANEL
Jun 20, 2007 08:31 PM
JonyyB
Jun 16, 2006 04:17 PM
Minarets
Jan 18, 2006 09:42 PM
