how hot is too hot?
Old Jul 7, 2011 | 10:04 PM
mroney's Avatar
Out here in El Paso my SS runs 210-220 alot. I have gotten used to it and now seen a problems with the car due to the temp.
Old Jul 8, 2011 | 12:07 AM
Originally Posted by jbman
Make sure you don't put to much coolant in, the normal amount is at the bottom of the bottle. I thought my Rad. was leaking but i had overfilled the coolant, dealer took awhile to figure that one out. Sounds like your fine.
I raised the cold level mark by 2 inches, & marked it with a Black Marker. Easier to see & lil more in reserve.
Before I did this tho, I made sure to see how high the level rises in summer, with full heat & running it pretty hard.
So no overflow, I have made sure of that..
